2006 4wd low will not engage
Old Feb 21, 2010 | 5:11 PM
cjb3303's Avatar
Unhappy 2006 4wd low will not engage
I have a 2006 Silverado and went to engage the 4 low today just to ensure it was working. You can hear the solenoids click but the light just flashed for a few seconds and it go back into 2 high. 4 high will engage and auto 4wd will engage but the 4 low just clicks and will not engage. Is this an easy DIY fix or something that I need to take into the shop for repair?
Old Feb 21, 2010 | 5:45 PM
gotstylez's Avatar
try putting it in nuetral then putting it in 4wd low.. in low you have to do this. in 4wd high you do not
Old Feb 21, 2010 | 6:46 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Do this to let the transfer case shift and then put it in gear and roll forward a little to get the axle to engage.
Old Feb 21, 2010 | 7:31 PM
cjb3303's Avatar
Thanks guys. I tried both methods again and still have the same results that it will not engage. You can hear the solenoids trying to engage when in neutral and the light will just flash while this is happening and then eventually goes back to 2 high. 2 high goes in just fine and the truck runs with no issues. I don't use the 4wd much but every couple of months or so I will cycle through the options and run it just a bit to make sure everything works. This weekend was the first time I have ever had any trouble. I thought maybe the cold had something to do with this but I drove over 150 miles today and tried to engage a couple of times with the same results. Any other thoughts or ideas are more than welcome.
Duece1123
Apr 15, 2017 3:37 PM
Junkin8ez
Jan 25, 2015 2:33 PM
Rmatt34
Dec 29, 2012 7:25 PM
grnmudz71
Jun 17, 2010 7:44 PM
swademaster
Dec 16, 2007 10:11 PM
