04 sub fuel pump with updated parts question
Old Apr 11, 2015 | 7:35 PM
Fwoodjr's Avatar
Default 04 sub fuel pump with updated parts question
Reading up about my issue with the fuel gauge being inaccurate and loss of power hard / no start and so on I found a tsb that describes my issues completely I mean every detail described is what is happening. It's Bulletin No.: 04-06-04-012C
Any how it says not to replace the fuel pump itself but to replace the strainers and sensor and provides the part numbers for both.
My question is I have just shy of 200k on the truck it wouldn't hurt replacing the whole module since I'm going that far any way. My question is and I cannot get an answer is if I went to Napa or Advance auto and purchase a delco fuel pump would it come with the revised parts since the bulletin is from 2006 I'd imagine so but I've had a similar issue with a power steering pump where it was updated but I could not get it as a packaged unit I had to purchase the revised part (one way valve was added) separately.
Any one have a answer for me please? And thank you.
Old Apr 11, 2015 | 7:54 PM
I do not know if the sending unit parts are updated for the aftermarket parts. I'm betting they are as the tsb was released in 2006. Even if its not updated, a new unit will fix the problem.
Smart to replace the complete module for a 11 year old pump will probably fail 2 months later if you just replace the sending unit...if your luck is like mine.
Old Apr 12, 2015 | 10:18 AM
Fwoodjr's Avatar
Oh my luck defiantly is. Just had the hub assembly bearing go on the driver side and knowing better and reading others post I only replaced that side. 2 weeks later I'm at it again on the other side. Thank you for the reply I already purchased the pump so I'm glad I don't have to take it back and re order parts. Stupid z models with there flex fuel.... Just an excuse to jack up all the prices. I can't even get ethanol in my area closest pump is over a hundred miles away!
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
gordeaux
Dec 11, 2008 6:30 PM
Stingray
Feb 22, 2007 12:08 AM
