Fuel Pump Keeps running
Old Apr 12, 2015 | 11:56 AM
SlickBR's Avatar
Default Fuel Pump Keeps running
Got an issue here that I haven't had any luck in finding a solution for... YES, I've tried the searches on several forums....
My wife has a 2001 Chevy Suburban LT, 4x2; this last Thursday night she came home, shut off the truck & upon removing the key, some thing kept whining under the truck. Once I got home, listened to the sound & laid down under the middle of the drivers side I determined it was the fuel pump.
I've read about the Oil Pressure Sensor being related to this is some capacity, but during some trouble shooting today, I don't think it is. I unplugged the Oil Pressure Sensor & the pump started running again, once the positive was reconnected at the battery.
Other Google searches have made mention of a Fuel pump flow control module, but I have yet to find any posts that talk about it causing the fuel pump to run constantly even when the keys are out of the ignition.
I really could use some assistance.
Thanks
Old Apr 12, 2015 | 12:08 PM
I'd be willing to bet that the fuel pump relay is stuck on, unplug the fuel pump relay...
Old Apr 12, 2015 | 12:37 PM
SlickBR's Avatar
Pulled the "F/PMP" relay & the pump is still running when I reconnect the Positive on the Battery.....
Old Apr 12, 2015 | 1:50 PM
Have you done any work recently what so ever under the hood or on the vehicle? there used to be a by-pass wire on the fuel pump for the previous body style that you could by-pass the fuse to power up the fuel pump but I don't think it was on the 2001 but it could be... the wire was bundled up near the fuse box but it would have to be intentionally connected....
bobthetechguy
Sep 29, 2014 7:57 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
mejung
Mar 19, 2011 8:01 AM
