'04 Suburban AC Issue
Old Sep 19, 2010 | 11:00 AM
Auxlarry's Avatar
Default '04 Suburban AC Issue
I need some help!
My Suburban has developed an AC issue. It has the dual Climate Control system and every once in a while on the drivers side it will go from full AC to full Heat. The only way to get the AC functioning again is to turn the ignition off and restart. Passenger side works fine.
What should I look for to correct this issue?
Larry
Old Sep 19, 2010 | 10:04 PM
Welcome to the forum.
Someone here might be able to help. Might try disconnecting the battery for 10-20 minutes.
Old Sep 20, 2010 | 6:18 PM
Auxlarry's Avatar
Thanks Shark!
I pulled the neg. cable today while I was cleaning my air cleaner. We'll see if that does the trick.
Why would this possibly fix this issue?
Old Sep 20, 2010 | 7:16 PM
Welcome to the forum, disconnecting the battery can reset some of the control modules hopefully get them working correctly... basically a reboot...
Old Sep 20, 2010 | 10:28 PM
It's the Chevy equivalent of Control, Alt, Delete.
Old Sep 22, 2010 | 6:48 PM
Auxlarry's Avatar
Thanks for the welcome and the help in2pro and 73shark! I like reading the topics here and the help will be put to good use. Hopefully my truck will continue to purr and I won't need much repair help....lol
Well, since I did the control-alt-delete the ac has not acted up, cross the fingers and hope for the best.
Thanks again fro the help!
Old Sep 25, 2010 | 7:45 PM
boondockdad's Avatar
2005 'Burb 2500 LT, exact same issue... happens once every couple months... very annoying
of course, had it in to the Chevy dealer, and the knuckleheads there gave me the old: "we couldn't duplicate the problem...", along with a $80 bill
Old Sep 26, 2010 | 11:39 AM
jwracin's Avatar
I am having the same prob with my c3500 now its getting were i can shut the truck off and it dosent all ways fix it Has anyone been able to fix this problem
thanks
Old Sep 26, 2010 | 12:18 PM
Thumper_ehhhhh's Avatar
Glad it worked out for you and to all the newbees on this thread welcome to the forums
williezoom
Jul 1, 2013 7:11 PM
CHEVYCRZY007
Jan 15, 2013 8:50 AM
timmy7728
Oct 20, 2012 7:31 PM
Stimpy911
Oct 12, 2011 2:40 AM
