04 Suburban AWD - Major Steering Problems - need help
Old Dec 31, 2015 | 12:13 PM
Doug Suburban's Avatar
Default 04 Suburban AWD - Major Steering Problems - need help
When I turn either direction (even as slow as turning into my driveway), it feels like the steering locks up - almost as if I'm holding down the brake at the same time.
This problem started seemingly out of the blue after driving for about an hour on the highway, I pulled off to get gas and suddenly noticed that it was having trouble steering at low speeds and tight turns.
Because of the distance that I was from home, I drove home on the highway like that but very cautiously. Then driving around town roads and making turns I really felt the problem. Made it home ok but after doing some research I really can't figure this out.
Initial signs are leading me to believe there is a problem with the differential - almost like one side is locking up as I begin a turn.
Any help would be great. I'm trying to figure out if this is a repairable problem for me or if a mechanic or dealer needs to be in the loop. I suspect I will need a shop to repair this - but going in, I want to have a better idea of what to tell them.
Thanks.
Old Dec 31, 2015 | 5:57 PM
In 4WD by any chance?
Old Dec 31, 2015 | 11:21 PM
No. It's an AWD vehicle with an inside switch that lets you go into 4WD-Lo by pushing the button while in neutral. I've tested this out a few times since the problem and I can hear the 4WD engage when I press the button in neutral and then disengage upon pressing again. It seems like the transfer case control and transfer case motor are working properly - as far as I can tell - when going into 4 Lo anyway.
Although the problem I'm having feels similar to making tight turns whilst in 4-Lo, it is more severe than that. I've experienced that before while trailering and although it's similar, it's not the same. It feels like all the wheels are locking up.
Old Jan 1, 2016 | 12:01 PM
cleveland63b's Avatar
Guess I haven't ever seen an awd suburban, but it sure sounds like its in 4x4 or possibly a bad cv joint
