04 Suburban wipers/cruise driving me nuts!
Old May 11, 2013 | 8:42 PM
dk2441's Avatar
Default 04 Suburban wipers/cruise driving me nuts!
So....the wipers only work on high, and don't "park" when they are switched off. Cruise control doesn't turn on when the button on the stalk is pushed. Washer and intermittent wipers don't work either. Turn signals and hazards do work. High beams flash with no problem but only come on when it's at "night" and the dash lights are on. I got lucky and found a new turn signal switch assembly for $37 and replaced it. But, same problems. I've checked fuses on the side of the dash and under the hood and found none blown. Any suggestions? UPDATE: I'm beginning to think this switch is bad. When I make left hand turns the high beams come on and I can "jiggle" the stalk to make the highs come on when they shouldn't. Still, seems to me the chance that the other problems are the same with the original switch suggests there's a problem outside of the switch.
dons2277
Astro
Jan 1, 2013 2:46 AM
Marrio62
Dec 21, 2011 1:43 PM
Mark Sladden
Nov 22, 2011 10:09 PM
mcphck
Nov 10, 2006 4:30 PM
