torsion leveling help
Old May 11, 2013 | 9:09 AM
vol_firefighter's Avatar
Default torsion leveling help
So I purchased my first Chevrolet Suburban which is a 2001 LS on Wednesday, today I decided to crank the torsion bar bolts to level it out. The front was 34 1/2 and the rear was 36 3/4. I made 5 full turns on the torsion bolt and it raised my passenger side to 36 3/4 but my driver aide to 36 1/4. Does anyone know why its a 1/2" off??
New to Chevrolets so don't know much about them. Would it fix itself after I get an alignment??
Any help would be appreciated, thanks
Old May 11, 2013 | 9:58 AM
country_09's Avatar
You're goin to want to crank it a lil more than what the back is if you want it truly "leveled". It's goin to settle probably 1/2" or so. And one side is higher than the other due to a more worn out torsion bar, at least that'd be my guess.
Old May 11, 2013 | 10:27 AM
Oh ok thanks a lot. So maybe 2 more full turns? And would it work if I did my driver side like 4 more turns since its a little lower then my passenger side?
Old May 11, 2013 | 10:49 AM
I guess my driver side torsion bar is just wore out. Because its maxed out now. and my passenger side still has a lil ways to go. But its looks pretty level now
Old May 11, 2013 | 10:26 PM
country_09's Avatar
Yeah you can crank one side more to make it level and not hurt anything. Basically a band aid for a lil while until you will replace the bars themselves
Droptine
2007 - 2013 (GMT900)
13
Feb 10, 2016 6:06 PM
Iowa07HD
Feb 23, 2011 8:19 PM
dankbud42o
Dec 11, 2010 1:39 PM
aftershock00
Jan 28, 2008 1:39 PM
99PewterZ71
Mar 24, 2007 12:56 AM
