05 Suburban Brake/Reverse Lights
Old Aug 27, 2010 | 6:33 PM
Mark B's Avatar
Default 05 Suburban Brake/Reverse Lights
Hello Forum,
This is my first post after having been lurking as needed. My problem seems common, but the solution still evades me. My first indication that I had a problem was on a road trip where the cruise control would not come up at all. I just thought I would look into it when I returned home, but as I found out that was a byproduct of my brake/reverse lights not working. I stopped at a rest stop and checked my fuse panel and when all looked good continued on my way. (Probably the full 800 miles with no brake lights! Yikes!) So, I have replaced the brake light switch w/ new, as well as the multi function switch w/ new. All fuses and bulbs are fresh. The battery was disconnected several times with these replacements. My third light was not functioning prior to this event so no help there. All other running, turn, flash, fog, headlight and accessories seem to work properly. The only issue is the brake and reverse, and the interior dome which may be related. Door courtesy lights work fine as do all other switchable overhead lights. I have tested the blue (running light) wires at the lamp with a test light and they are getting power, but nothing at the brown wire. I have read here that there may be an issue at the ground, but I am not sure about where this ground is located on the frame or body. Sorry to be so wordy. Trying to provide as much relevant info as possible on the first go round. All advice is appreciated! Have a great day guys! Mark B
Old Aug 30, 2010 | 2:40 PM
aking0408's Avatar
Default Double-check fuses?
To satisfy my own curiosity, did you check the TCB2 (I think it's that one) fuse in the left dash? I know that is tied in with the dome lamps. Might be related to your issues here as well?
--I know you have replaced everything but that fuse is easy to overlook and I missed it when diagnosing a dome lamp issue.
Old Aug 30, 2010 | 8:43 PM
Welcome to the forum.
Old Aug 31, 2010 | 9:51 AM
Mark B's Avatar
Default Thanks!
aking0408,
That fuse was bad, and did correct the dome light issue, but unfortunately, it didn't correct the brake or reverse light problem. I thank you for your input! It's great to have a forum like this!
Thanks for the welcome!
Mark B
tokillamurderer
Aug 21, 2011 8:09 PM
skdevore
Aug 26, 2009 10:18 PM
d1nonly34
May 9, 2009 10:21 AM
d1nonly34
Apr 2, 2009 11:14 AM
myCHEVYkicksass
Nov 21, 2006 12:11 PM
