05 suburban rear wiper
Old Nov 5, 2011 | 3:30 PM
fords_suck's Avatar
Default 05 suburban rear wiper
I have an 05 suburban and I started to notice that the rear window wiper was sporadic when I would turn it on this summer. I was out of state for a little bit and let my parents use my car for the boat. I got back and the rear wiper hasn't worked at all. I was wondering if anyone know what I can do to fix it that would help me out.
Old Nov 5, 2011 | 11:19 PM
Welcome to the forum.
Is the wiper arm firmly attached to the motor shaft?
Does the motor shaft turn?
Old Nov 18, 2011 | 1:05 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Could you please provide some additional information so we can research this issue? Does the motor run at all when the wiper is turned on? Can you hear it making any noise? Any additional information you can provide will help in resolving the issue. I look forward to hearing from you!
Louis
GM Customer Service
Old Nov 28, 2011 | 1:49 PM
boondockdad's Avatar
I'm having same problem. 2005 LT 2500 Suburban
The motor does not activate... no sound, no nothing
It's been this way for about the last two years.
What's strange is, since it stopped working, on a couple of occasions, I've popped the upper glass, and the arm cycled once.
Old Nov 28, 2011 | 3:01 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> boondockdad,
I have researched this issue and haven't come across any Suburban wiper issues in my resources. Have you had it inspected by your dealer? If you have further questions, feel free to contact me, here or via PM. I look forward to your response.
Louis
GM Customer Service
ruley73
Sep 15, 2017 8:11 AM
BadDad
Jan 18, 2014 10:17 AM
New_To_Suburban
Aug 31, 2011 11:31 AM
hossler
Jan 15, 2010 5:50 PM
gmares
Feb 4, 2006 5:39 PM
