06 Suburban , no sound through DVD help
just bought an 07 suburban and headsets work work ... the red lights on the dvd player are lighting up . .. where is the IR emitter located ?is it in the radio itself and how does the digital camera trick work exactly
Can you guys help me a little, my family just recently bought a 2006 Chevy Suburban, and it was used, and were trying to figure out the DVD system. I wanted to know if the driver and passenger can listen to music or the radio while the other passengers watch a movie, we have wired headphones, and it wouldn't let use do both, so we are considering buying wireless, but will it still not let us do both at the same time?? I NEED to know this, because we are going on a trip in 1 week !! :/
Welcome to the forum.
I know you can listen to do different sources on the new ones and I believe you can on the older version with wireless headphones. I think the owners manual would tell you if you can do that or not.
This thread sounds like a problem I am currently experiencing with my 2007 Suburban. I have the dual DVDs in the headrests and just got some new headphones for the kids. I'm getting some feedback in the left channel. You mentioned to check the wiring for a short or a grounding issue. Where would I look for that?
I ended up getting new headphones - which helped. However I still have slight feedback on the left side. Additionally - now the drivers side head unit stopped showing images even thought the screen is on. I'm guessing the video cable is bad or disconnected somewhere but I haven't figured it out yet.
For anyone having trouble getting sound out of their wireless headphones and you have tried everything from changing the channels as well as the batteries and your still not getting sound, then more than likely it is the IR Transmitter (Control Module) in you roof mounted console. Another way of knowing is the IR lights don't light up or only half of them are lit I such as in my case.
I scratched my head time and time again and also took it to a Chevrolet dealer as well as two audio places and they had no answers for me. I finally thought of a buddy of mine whom owns an audio store in my home town and he got the schematic and found that it could only be the IR Transmitter (control module) that sends signals to your headphones, so I went ahead and bought one from the local Chevrolet dealer.
I pulled down the console, switched out the IR Transmitter (control module) and hooray.......it's working once again. All the little red lights came on and I instantly got signals through my headphones.
Hi
I recently bought a Tahoe 03 and the last owner did a poor job installing a ouku android head unit. They have cut away the original harness and tried to twin and tape the wires together
This resulting in that the steering wheel controls, overhead DVD player and rear seat audio control unit is not working any more
I now soldered the wires i know what are doing, but i´m clueless to my other problems..
PPL-purple this wire must be the Rear seat audio enable signal..
I´m sure that this is the reason the RSA is not working.
But what is the signal? can i just connect it to the IGN ?? or is it waiting for a pre-sett voltage?
How do i turn it on?
There is 4 wires coming from the right side when looking in the empty socket when the head unit is removed..
Brown/white
Black/white
Grn/white
and a bear wire
I suppose this is the wires form the RSE Overhead DVD player..
but when i connect them there is only static..?? what am i doing wrong?
And the last problem with the steering wheel controls:
I thought that the org wire 0.35 was the right wire to connect to the K1 wire on the head unit.. but no... nothing happens
The internet tells me that the right wire should carry around 5v but the org 0.35 is only around 0.5 ???
I´m lost now and feel like i have tried everything..
Please can somebody help a tired norwegian out
Thanks
Gorm
Brown/white
Black/white
Grn/white
and a bear wire
Thanks
Gorm
