07 5.3L Suburban -- where to fill coolant?
Old Feb 19, 2010 | 5:26 PM
McGuireV10's Avatar
Default 07 5.3L Suburban -- where to fill coolant?
I'm at 50K on my 2007 K1500 Suburban which is where I normally flush the coolant and trans. Yes I know this is earlier than the recommended intervals, and I know about adding the pellets. There is no radiator cap; where do you refill the coolant? First vehicle I've owned where this isn't obvious (and this one is #55 of 57 I've owned, so I'm hardly new to this).
Heck, as long as I'm here -- is there a regular radiator drain on the bottom, or is there some new complicated way to do this, too? I didn't think to look earlier today while I was under there.
Thanks!
Old Feb 19, 2010 | 6:53 PM
s34n's Avatar
how full is your reservoir? i've never heard of there not being a radiator cap. im not sure if gm has changed alot but there should be a petcock on the bottom of the radiator it might be hidden.
Old Feb 19, 2010 | 9:22 PM
McGuireV10's Avatar
Well, now you have heard of it: there is no radiator cap.
A couple hours ago a friend told me he filled his diesel's coolant system through the reserve tank. I read somewhere else about someone pulling the thermostat and filling up there. Surely there is something less half-baked than this???
Old Feb 19, 2010 | 9:42 PM
ousig2408's Avatar
looking in the manual on pages 462 and on it seems that yes you have to fill through the "coolant surge tank". it also says the stock coolant is good for 5 years or 150000 miles... there may be a drain plug on the block.
Old Feb 19, 2010 | 9:59 PM
nauticstar87's Avatar
I have the newest body style Chevy, and i have a cap on my Radiator. That's odd you don't. but Chevys SUV's are more stylish than th eold body style. Guess they think if you don't buy the Truck, your not gonna do your own maintainence.
Old Feb 19, 2010 | 10:47 PM
gotstylez's Avatar
http://2.bp.blogspot.com/_1XknPAfZhc...ban+engine.jpg
porbably unbolt that plactic piece on top and its right there.. if not just fill the reserve tank..it all goes into the same place lol
Old Feb 20, 2010 | 8:52 AM
8rings's Avatar
Fill it from the expansion tank. You will have to run the truck, turn the heat to high, and then fill the tank again after the new coolant circulates. Of course if you are just topping up you don't need to do this.
Old Feb 20, 2010 | 8:58 AM
TomS209's Avatar
No drain for the radiator on mine. Took it to Jiffylube and they use a machine that they insert into the overflo tank that sucks out the old while putting in the new. Cost me around 100 bucks.
Old Feb 21, 2010 | 8:51 AM
McGuireV10's Avatar
Thanks folks, I guess I'll use the reservoir tank.
There is so much plastic under, above, and around this engine... crazy. No drain plug evident. Because of the front transfer case and axles I can't even see enough of the block to tell whether there is a drain plug somewhere on it. I may be firing up the fluid vac and draining it the Jiffy-Lube way myself...
About that plastic strip -- that was the first place I looked... Nothing under there but more of the metal support that sticks out of either end. Seems to be useless.
Convenient how the quoted service lifetime is juuuuust enough to get you out of warranty, isn't it?
Old Feb 21, 2010 | 1:48 PM
Hardin Thicke's Avatar
Originally Posted by McGuireV10
.....I know this is earlier than the recommended intervals, and I know about adding the pellets......
I'll bite....pellets? What pellets? .....I've got 65,000 on on my formerly oft driven, now weekend ride.
