07 Denali Taillights...
#12
RE: 07 Denali Taillights...
ORIGINAL: 70mopar
Slammed Birch, did u order factory LED Caddy lights, or r they aftermarket? just asking, 'cause i coulda swore ZX said the new Cad lights won't fit. let us know what u'r getting.
My interpretation of ZX's post was that they will fit, but he hesitated to recommend it because he thought some people may not be quite up to the install. I have no doubt that the lights will physically fit in the opening. What I am curious about is the harness. I haven't bothered taking a stock light out to look, but I am expecting to find a pigtail with a weatherpack for the incandescent bults that can be removed. The harness for the LEDs should then plug in to the chassis harness. I could certainly be mistaken, but if I know GM, this swap should be just that simple.
Perhaps ZX will comment on my speculation?
#13
Lots of "it should" and "what if's"... When someone does the install of the Escalade Tails and it works, would you please tell us how it went and what to expect? Thanks guys! You are right, knowing GM it should be Plug/Play.
#15
Slammed, alot of ppl have a "connection" with someone @ GM, that's not what i was asking (regarding the $ u'd pay). u answered my question none the less regarding OE or aftermarket. thanks, & i had the same idea regarding the connection for the tail light wiring. post some pic's/info when u get it done.
#17
How many wires in the harness, and could a harness adapter be made with connectors (how could one get the connectors?) or could the wires be joined using a homemade connector or through splicing (safely)? One would have to find out if colors of wires don't match what wire is what to match up? Any help from our master engineer/advisor would be helpful. In my view the piece fitting physically with same bolt points/etc. is 75% of the battle...
#18
got escalade taillamps for my 07 suburban .they did not fit...the body of the lamp is the same but harness is a problem
07 subs and tahoes have a 5 pin connector and escalades have a 6 pin conn.lamps look really good on the truck to bad they didnt work
