07 Lockpick/Superlockpick GEN 3
Old Jun 25, 2007 | 5:48 PM
tomm's Avatar
Default 07 Lockpick/Superlockpick GEN 3
Ok, I installed this and it worked as promised but not for long. When I put the vehicle in drive the lock message comes up and I hit the mute button 4 times and wow... IT WORKS!!! But then I drive over 6 miles an hour and then BAM the screen lock comes on. If I drive under 6 miles an hour or stop...It Works again.
So the Nav see's that I am moving and it prevents me from viewing. So I read the instructions and it says to override the nav fuction to hit the doorlock lockout button 4 times and BAM it works while driving but after 60 seconds BAM the screen lock comes back on. I see the instructions state that the Nav override only lasts 60 seconds so what they heck do I do?
Anyone have one of these in their 07's that actually works?
Thanks!
Old Jun 25, 2007 | 8:17 PM
Snowman's Avatar
Default RE: 07 Lockpick/Superlockpick GEN 3
I just bought and installed my Super Lockpick in my '07 Tahoe and it works just as advertised. First I would check the dip switch settings. If that doesnt work, contact CoastalETech. I have some installation issues and they responded quickly and professionally.
Snowman
Old Jun 26, 2007 | 8:54 AM
ironcy's Avatar
all you should have to do is press the mute button 4x...that should activate the device until you disable the feature or turn off the vehicle.
-b
Old Jun 26, 2007 | 10:21 AM
Nikos72's Avatar
Ok as far as I know the door lockout isfor nav functions and the mute is for movies.
My first question is what are your dip settings at
Second is do you have a factory rear camera
If not did you connect a video source and what is your production date
The nav override is only to enter an address or find a destination while moving, also this function is to change categories on cd or xm function and will last 60 sec at a time.
Old Jun 26, 2007 | 12:52 PM
tomm's Avatar
I had the dips set for automatic but after speaking with the manufacture automatic control is only available for early production builds. My Tahoe was very recent (I just purchased it 2 weeks ago) and the build was just a few months back so automatic settings are not compatible. Changing the dips per instructed everything now works but you have to hit the mute button 4 times everytime you want to activate it.
Old Jun 26, 2007 | 1:10 PM
Nikos72's Avatar
Well at least now you know its working properly good luck
Old Jun 27, 2007 | 10:21 AM
neweagle's Avatar
I have this too, and it works as advertised. The 60-sec shut-off comes after that long of a period of inactivity. I've spent longer than that settting up a nav route, and as long as I'm entering data, it never shuts off.
Boris
Nov 4, 2012 9:54 AM
MontanaMike
Jun 9, 2011 2:28 PM
wysilverado
Aug 13, 2010 9:21 AM
jdkluck
Apr 10, 2007 4:33 PM
dkennel
Mar 26, 2007 6:50 PM
