07 LT3 Nav radio questions
Old Oct 10, 2009 | 2:50 PM
sermis's Avatar
Default 07 LT3 Nav radio questions
I know this forum is littered with Nav radio questions but i am lost on an issue when looking for the GM Nav radio for my truck. I want to buy a GM NAV radio to replace the BOSE radio that came with my LT3. My Tahoe DOES NOT have the overhead DVD player however it DOES have the rear AM/FM/XM rear console entertainment center. looking for the NAV radio that goes with my vehicle that will allow the back console radio and my steering wheel controls to work like they should with the NAV radio I need. My glove box has RPO Code UQA, UE1, w/o RPO Code HP2, U42. Can anyone help me? I would like to find the radio i need off the internet instead of paying an arm and a leg from my dealership. Thanks in advance !!!!
Old Oct 13, 2009 | 4:11 PM
jtstoner's Avatar
I have a NAV unit I just took out of my 2007 LT3 Suburban. It is programmed for a rear entertainment system, but should work fine in your vehicle. It is my understanding that the key is finding a tech who has some experience doing this kind of programming and patience to take the time to get it right. If you are interested any further, PM me.
Old Oct 13, 2009 | 5:56 PM
shawnvw's Avatar
Banned
the only difference in these nav radios is whether or not it will play a DVD, other than that, as jtstoner said....its all in the programming
Old Oct 13, 2009 | 9:26 PM
Hardin Thicke's Avatar
Originally Posted by sermis
........I want to buy a GM NAV radio to replace the BOSE radio that came with my LT3.........
Just a slight clarification. Be it good or bad, Bose does not make the "radio". I believe the head unit you're describing is made by Denso.
Old Oct 13, 2009 | 10:15 PM
jtstoner's Avatar
Or Delphi. The unit I just pulled from my Suburban was made by Delphi.
Old Sep 20, 2011 | 5:57 PM
AndrewEvan's Avatar
Hey guys! I'm new here and enjoying the threads, lots of collective knowledge. I stumbled onto this thread b/c my stereo is running in some form of safe mode since a disc got stuck in the head unit. For months, when the key was in the "on" position, the head unit would attempt for several minutes to dislodge the stuck disc, until finally, it gave up? Oddly enough, the unit no longer powers up upon starting the truck. I have to manually push the button for the clock to appear and strangely, for the back up sensors to work. Soooo... my question is, can I simply replace the unit with another oem "bose" head unit and expect all accessories, ie steering wheel controls, back up sensors, xm, onstar, and whatever else that thing does, to work? Any help is appreaciated. Oh, it's 07 tahoe lt3 with the bose upgraded NON navigation head unit. Thanks!
Old Sep 20, 2011 | 7:48 PM
ChevyFreak's Avatar
I hate to post in an old thread. It's usually easier to just start a new one. However, since you have asked, I will in this case, to answer your question.
Theoretically, yes, everything should work just fine. You may have to have it programmed by the dealership, but I cannot be certain about this for the non navigation units. Either way, everything should work, assuming there are not any other issues with your truck - like the back up sensor issue you mentioned (weird ) ... Just make sure you buy a Bose system.
Hope that helps! Good luck!!
Old Sep 21, 2011 | 7:59 AM
AndrewEvan's Avatar
Thumbs up
Thanks for the info!
Old Sep 21, 2011 | 2:11 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> AndrewEvan,
I recommend taking the vehicle to the dealership. They will be able to look at your vehicle and see if it needs to be programmed. Keep us updated.
Breanne
Chevrolet Customer Service
Old Sep 22, 2011 | 8:02 AM
SabrToothSqrl's Avatar
Default yea
I recommend NOT taking your vehicle to the dealership.
Did you know that dealerships are only there to make money? the sneaky bastards...
Any and all future 'see your dealer' messages will be met with similar posts.
You are not adding anything useful to the conversation. You are not providing any new information. You are thus SLOWING the resolution and wasting everyone's time. KNOCK IT OFF and go find a real job.
adamant
Feb 15, 2009 8:49 AM
cmonteiro1
Jan 8, 2009 9:32 PM
rkeller803
Feb 9, 2008 12:33 PM
NJacobs415
Jul 26, 2007 11:50 AM
MuskyHunter
Aug 29, 2006 3:06 PM
