07 Suburban 5.3 no start after head gaskets
Old Feb 16, 2023 | 10:35 PM
Boostaddict91's Avatar
Default 07 Suburban 5.3 no start after head gaskets
Hey all,
I have a 07 suburban that I just replaced the head gaskets on due to a miss on cylinder 1 & 3. I had previously replaced ecu, plugs wires and coil left me to think it was a leak between cylinders anyways today I got it all back together finally and when I went to start it, now it just cranks no start. It has fuel and compression I dont have a way to check for spark but im assuming the truck is disabled the spark for some reason. Im scratching my head on this. All injectors were plugged back in, in their correct place.
Old Feb 17, 2023 | 8:47 AM
04Z71SuburbanDude's Avatar
Originally Posted by Boostaddict91
Hey all,
so to check for spark, take the coils off of the spark plugs and hold them close to a piece of metal (somewhere on the engine) and have someone turn the engine over and see if you get any spark. if not. that's your problem. if you do get spark go get a compression tester from AutoZone and check to see if you have compression in all 8 cylinders.
Old Feb 17, 2023 | 5:41 PM
So it's a bad ground, I jumped ground from coil rails to a known good ground and it fired right up. Apparently this is a fairly common issue on these trucks. Still has a random miss occasionally on 1&3 so dunno about that.
Old Feb 19, 2023 | 9:40 AM
try replacing the coils on 1 and 3 and see if that fixes it
Old Feb 19, 2023 | 10:33 AM
repairman54's Avatar
Save yourself money and swap the coils and wires with other cylinders first and see if miss fires move to them. Check the plugs also. You can swap plugs also.
Old Feb 20, 2023 | 7:24 AM
yeah I didn't mean to say it like you had to buy new coils but always swap coils around to see if the problem follows the coils or not. my bad.
Boostaddict91
Apr 23, 2022 2:53 AM
96 CC
Nov 11, 2021 10:43 PM
Tommy Baughman
Jan 12, 2018 5:05 PM
Gray_wolf_7
Feb 20, 2015 6:16 AM
steelhorse123
Dec 25, 2008 12:02 PM
