07 Suburban Check engine light on
Old Jun 7, 2015 | 1:56 PM
Bbev2012's Avatar
Default 07 Suburban Check engine light on
Hello everyone, My wifes 07 Suburban has a check engine light that decided to pop up and say hello.in the meanwhile, the oil pressure gauge decides to peg at 80 then to 60 and back to 0 when it feels like it. I tried connecting an obd 2 scanner and for some reason it wont link. My friend had an issue with an a sensor that controlled the gauge. He crawled up there and unplugged it while the key was on and the gauge was acting a fool. Has anyone had this problem? if so what is the remedy? It has oil and its a little on the high side. I plan on changing it today, and it it has been running as normal. It has 101xxx on it and we just got it about 2 weeks ago. I figured something would go wrong eventually but not this soon. Any help will be greatly appreciated.
Old Jun 7, 2015 | 2:56 PM
Welcome to the forum..
If there is no power to the ALDL data link connector check your fuses... I think its the same one the 12v outlets get there power from...
Check the power to pin 16
Old Jun 8, 2015 | 5:15 AM
Bbev2012's Avatar
Thanks for responding. I will check the fuses but when i plug it it it comes on and says "linking" but it winds up not linking. Its my dads and he said it maybe his machine. But I will check the fuses. Appreciate it!!
Old Jun 11, 2015 | 3:17 PM
Bbev2012's Avatar
Thanks for all the help.. The obd scanner was not working properly and I got the oil pressure sensor changed out after cussing at it but i got it...
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
