07 Tahoe 2wd rear axle gear change
Old Sep 30, 2006 | 10:44 AM
flstfse's Avatar
Default 07 Tahoe 2wd rear axle gear change
I have a 2007 Tahoe with the 3.42 rear axle gears and the 20" tire package. I have not been real pleased with the performance. I am considering changing to a 3.73 or a 4.10 axle. 2 questions, those who have these gears can you give me your rpm at 70 mph for each? Also, the 4.10 was not offered on a 2wd. Would it be possible for the dealer to flash the TCM or PCM for either of these ratios if replaced? I am thinking my local dealer may be the best place to have all the work done for warranty, computer flshes, etc.
Thanks.
Old Sep 30, 2006 | 2:11 PM
ZX1100F1's Avatar
Default RE: 07 Tahoe 2wd rear axle gear change
To get an idea of what the RPM change will be add 180 RPM to where you're at now for 3.73 and another 180 RPM for the 4.10.
The dealer can flash for the gear-set change, they have to get a new VCI number from Tech-link.
Go for th e 4.10's.
Get out your wallet.
Old Sep 30, 2006 | 7:28 PM
flstfse's Avatar
Thanks for your reply. So if I understand, no problem with the 4.10 even though it is not offered in a 2wd?
Thanks
97Silverado1500
Nov 7, 2012 3:50 PM
bigava@comcast.net
Dec 19, 2011 10:29 AM
RBuscemi
Jul 10, 2011 1:16 PM
jrsavoie
Dec 4, 2010 12:25 PM
4x4chvyman
Sep 2, 2008 5:52 PM
