07 Tahoe Brake Squealing?
Old Jul 29, 2011 | 12:57 AM
ambiguous216's Avatar
Default 07 Tahoe Brake Squealing?
Hello All,
I have another problem that started recently on my 07 tahoe. When I back up or go forward there is a squeal noise coming from the passenger front wheel. It sounds like metal on metal and when I hit the brakes it feels like grinding on my right foot. Could this be the caliper not releasing or is this a bearing issue? Any help or advice would be appreciate.
I just changed the brakes about 8 months ago and probably have about 15K miles on it.
Old Jul 29, 2011 | 7:31 AM
JimJ's Avatar
I'd be pulling the tires off to see what I had screwed up and possibly see if the warning tab was positioned correctly.
Old Jul 29, 2011 | 11:41 AM
Official GM Rep
ambiguous216,
I am sorry to hear that you are experiencing this issue. Did you change the brakes yourself or did you have your dealer do them? Also, have you brought this issue to your local dealerships attention?
Thank you,
Elizabeth, Chevrolet Customer Service
Old Jul 29, 2011 | 2:19 PM
RacerX's Avatar
Bad Bearings only make noise when they are loaded.
You have a brake surface issue. Take off the wheel and remove the caliper, See if there are any gouge marks on the surface of the brake pad. Then remove the rotor and look for grooves on the surface of the rotor. I think you have a grooved rotor on the RF side. A tiny groove in the surface can give you a whine/squeal when the brake pads are applied or a grinding sound(which is actually air vibrating between the rotor and the pad).
If you suspect something you can have the rotor resurfaced or apply one of those spray on anti-squeal treatments to the brake pad surface.
Old Jul 29, 2011 | 2:24 PM
kevinkpk's Avatar
Thats what I'd suspect.
Old Jul 29, 2011 | 2:26 PM
kevinkpk's Avatar
Originally Posted by ambiguous216
Hello All,
If a caliper where grabbing, you'd definatley know it. I also agree with racerx reply.
Bill C.
Sep 21, 2012 8:32 PM
4saints4
Apr 17, 2008 10:10 AM
judy may
Colorado
Feb 4, 2008 1:12 AM
hoytheld
Feb 6, 2007 8:55 AM
ButchA
Jan 8, 2007 7:00 PM
