07 Tahoe clock
Old Apr 1, 2007 | 11:47 AM
jj's Avatar
jj
Default 07 Tahoe clock
Hi, I'm a new member with an 07 Tahoe and the clock has disappeared from the uper right corner of thenav screen; also clock does not show up on the blue screen when nav/ radio unitis powered off!Nav and radio are receiving GPS signal ok. Any ideas? Thanks..J.J.
Old Apr 1, 2007 | 1:08 PM
biglg's Avatar
Default RE: 07 Tahoe clock
Is this in a garage? DId you install the nav unit, or from the factory? Have you disconnected the battery cables?
If any of the above apply take the tahoe out and drive it around it should start to show up again.
Old Apr 1, 2007 | 1:23 PM
jj's Avatar
jj
Tahoe is outside, factory nav. I have not disconnected battery cables.At start of 500 mile trip I had clock at about 250 miles clock disappeared! ...J.J.
Old May 22, 2007 | 9:24 PM
jgolo's Avatar
I have a Silverado and it does the same thing. sometimes it's there and sometimes it's not.
I cannot figure out exactly what causes it -remote start? no remote start? turning off with XM on or CD on.
Weird?
Old May 22, 2007 | 11:16 PM
Seems like there was a mention on this forum of certain MP3 CDs causing this. Might try a search.
Old May 23, 2007 | 9:47 AM
jj's Avatar
jj
Upon insertion of any MP3 disc in the cd player the clockwill disappear off the right coner of the Nav screen as soon as the Tahoe isrestarted. If the disc is removed the Tahoe must be restarted to get the clock back on the Nav screen..
Old May 23, 2007 | 4:54 PM
tahoe07's Avatar
Tryhaving your dealer look at...
TIS software calibration (part # 15260985) update that your dealer can download into your unit under warranty.
I believe it is the one for the clock issue and other display problems with the radio.
ZX will have to confirm.
Old May 23, 2007 | 5:36 PM
ZX1100F1's Avatar
The disappearing clock is a known issue that Denso is working on, currently there is no fix for this annoying little problem.
Old May 23, 2007 | 8:55 PM
sjenkinzz's Avatar
Let me tell you what happened to mine yesterday.I have an '07 LTZ with all the bells and whistles. Went to the bank yesterday. Upon arriving at the bank cut it off. Naturally the radio was still playing as normal. Once I opened the door, the radio is supposed to quit, right. Well it was still playing. Tahoe off and keys in hand. Went into bank. Got back in and radio still playing. Cranked and radio cuts off. Would not come back on for a minute or two. Strange.....
Old May 23, 2007 | 9:40 PM
You are really lucky. Most of us prior to the fix couldn't let our radios play for two or three ten minute cycles without having to jump to start.
