07 Tahoe Fuel Gauge Dropping out
Old Oct 27, 2008 | 9:35 AM
EPJ's Avatar
EPJ
Default 07 Tahoe Fuel Gauge Dropping out
The Little Misses 07 Tahoehas a problem with the fuel gauge, we plan on taking it in but beacuse it also has a check engine light butwas seeking wisdom from the GM Guru's on this site. You People were great when I upgraded the Power Mirrors to DL3's. Any input or assistance would be greatly appreciated!!!!!!!!!!!!
Old Oct 28, 2008 | 10:59 AM
Default RE: 07 Tahoe Fuel Gauge Dropping out
Any code info?
Old Oct 28, 2008 | 1:32 PM
EPJ's Avatar
EPJ
Sorry! I guess a little more info would help, It has not been scanned to pull the code and the wife is pretty sure the code did not set when the gauge started acting up. When the gauge drops out it does not give a low fuel warning but the miles to empty shows dashed lines!!!! I would think dashed lines on miles to empty would also give a low fuel! I filled the truck about 200 miles from home and the gauge did not act up any more until it got to a little more than 1/2 . When the gauge does act up it goes right below empty and seems to move down a little more when the key is turned off.The engine light stays on. Thanks again
Old Oct 28, 2008 | 8:49 PM
If the "Check Engine" lite lit, then it should have a code. Most auto parts stores will scan for free.
Old Oct 31, 2008 | 4:59 PM
SabrToothSqrl's Avatar
define "problem" if it goes down too quickly... drive slower?
SAVE GAS: Brake Less.
Old Nov 1, 2008 | 2:30 PM
EPJ's Avatar
EPJ
Fuel Gauge sending unit replaced under EXTENDED warranty. Thanks for the responses
pdrayton
13
Dec 11, 2014 1:06 PM
blaze_32001
Feb 29, 2012 5:15 PM
NMguy
Dec 14, 2011 9:49 AM
nemo3xm
Aug 30, 2011 3:37 PM
Rowdy1
Sep 1, 2010 4:09 PM
