07 Tahoe suspension skeaks
Old Dec 1, 2009 | 10:33 AM
crawfors's Avatar
Default 07 Tahoe suspension skeaks
Any ideas as to the cause of this? When it starts getting cold outside my suspension starts squeaking when I make turning into driveways or go over bumps in the road. This has happened since now for two winters. Last year I took it to the dealer and they greased the chasie. But the problem returned. It is not noticeable until the weather gets below 50%. Any ideas?
Thanks Shannon
Old Dec 1, 2009 | 10:42 AM
myotherchevyisablazer's Avatar
have you checked all the bushings?and i would go around making sure it's all snug as well
Old Dec 1, 2009 | 2:38 PM
freyguy's Avatar
Could be alot of things, but when mine was squeaking, it turned out I had a busted lower ball joint boot, and a busted boot on one of the tie rods. Give them a check, because most are not serviceable.
Old Dec 3, 2009 | 4:49 PM
Not sure what greasing the chassis means as there are only two zerks, one on each outer tie rod ends. Spray silicone on the roll bar bushings and end links.
Old Dec 6, 2009 | 12:36 PM
DeeZ's Avatar
Ride of the Month
August 2009
Squeaking could be normal as well. It doesn't always mean there is something wrong. Wouldn't hurt to check everything anyway.
Deez
Old Jan 2, 2010 | 7:21 PM
grandcas's Avatar
hey thank you for the sugestions here, my 07 tahoe has the same problem and I'll make the adjustments to those parts... regards
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
john4a73
Dec 5, 2012 1:27 AM
mcdten
Sep 5, 2012 4:18 PM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
dmacauley
Aug 23, 2007 9:24 AM
