07 Tahoe Transmission Slipping
Old Nov 15, 2012 | 9:52 AM
CrewCabFan's Avatar
Default 07 Tahoe Transmission Slipping
07 Tahoe 65,000 miles.
Was drving my wifes tahoe and I noticed the transmission slipping. When I get up to about 55 and it shifts into the last gear the RPMs rise and then in shifts. Any ideas what I need to look far?
Old Nov 15, 2012 | 9:21 PM
MDTAHOE's Avatar
Professional Mechanic
If the fluid level is ok then you need to look for a new transmission.
Old Nov 15, 2012 | 10:24 PM
CrewCabFan's Avatar
Nothing else can be done? Just wondering what new transmission would cost?
Old Nov 17, 2012 | 1:41 AM
cleveland63b's Avatar
check the fluid and if you still need convincing pull the pan and look for metal shavings
as for cost theres about a thousand different routes you could take so its a guessing game until you do some research of what you want
Old Nov 18, 2012 | 12:22 PM
GM parts direct list if for $1600... I'd check a local parts shop for a re-manufactured unit...
Old Nov 19, 2012 | 8:22 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> CrewCabFan,
I’m sorry you are experiencing this issue with your Tahoe vehicle. I agree with the other posters, check the fluid first. The issue you are experiencing may be due to a distressed 2-4 band and/or 3-4 clutch. This is just a suggestion, not a diagnosis.
I recommend having the vehicle inspected by a certified technician for an official diagnosis.
Please keep us posted. If you need additional assistance locating a technician, please PM me your zip code.
Louis
GM Customer Service
puffer
Sep 4, 2015 11:25 AM
zachsny
Nov 15, 2011 7:19 PM
HD6.0
Sep 5, 2011 12:34 AM
my99s10
Jun 15, 2009 8:33 AM
