08 Suburban no front AC or Heat
Old Nov 3, 2017 | 12:08 PM
Ladmarines's Avatar
Default 08 Suburban no front AC or Heat
So I did a search and I did go and get another Blower resistor 2 of them one from Rock auto and one from AutoZone but this did not fix the issue. I get power across the device and when I jump power the blower motor does run and blows cold. My question is there is a small third wire coming off of the plug does anyone know where this could go or if there is a relay somewhere. the fuse under the hood looks good to.
Old Nov 3, 2017 | 12:10 PM
Ladmarines's Avatar
pic of plugs. when it is all hooked up I get power across the circuit. is that small brown/White wire like a control from somewhere?
Attached Thumbnails 08 Suburban no front AC or Heat-20171102_174112%5B990%5D.jpg
Old Nov 4, 2017 | 6:34 AM
a55bruce's Avatar
The third wire is from the HVAC Control Module. It's a speed signal (don't know if it's pulsed or proportional) to the "Blower Motor Control Module" (aka the resistor).
They use a solid state speed controller now instead of resistors to control the blower speed.
Make sure you have a good ground (BLK wire) on the 3-wire connector.
There are at least 3 Fuses to check...
HVAC BATT....Power to the HVAC Control Module.
HVAC BLWR....Power to the Blower Motor
HVAC-IGN.....Power to the HVAC Actuators
