Old Jul 29, 2015, 12:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
08 Tahoe 5.3 Thermostat Change
Old Aug 19, 2009 | 1:09 PM
JesseC's Avatar
Default 08 Tahoe 5.3 Thermostat Change
Are there any tricks to changing the thermostat in a 2008 FlexFuel Tahoe with the 5.3? I found that on my 99 2 door that I had to fill it with coolant with the old thermostat out and when the fluid reached the top of the intake, I would put the thermostat back in before finishing. By not doing this, I had issues getting the fluid to flow. Is there anyting like this on my new Tahoe or is it just drain, replace thermostat and replace?
Old Aug 19, 2009 | 1:43 PM
myotherchevyisablazer's Avatar
why are you changing the thermostat on your brand new truck?just wondering
Old Aug 20, 2009 | 8:32 PM
JesseC's Avatar
One of the first things I have always done is to change the thermostat to a cooler one. My 99 Tahoe ran a 180 degree thermostat and at 140,000 miles still did not smoke after being started after sitting for a few weeks. I just like to cool them off a little from the 195 that comes stock. No baking the internals at 210 all the time. It also helps with trans temps while towing which I do a lot of. So, back to the question, has anyone changed one on a 5.3?
Old Aug 22, 2009 | 4:12 PM
15 Year Member
Not a good idea w/ the NBS as the whole system is set up to run at 200*F. If tranny temp is a concern, then put on a cooler, either the one that comes on the HD pkg or an aftermarket one.
Old Aug 24, 2009 | 8:09 AM
SabrToothSqrl's Avatar
Default 210
I am fairly sure engines run 200-210 for a reason, between oil temps, emmissions issues, etc...
however if you really want to do this, I would imagine you just swap them out.
Id wait until the 5 year 100,000 power train is up however.... or at least the 3/36...
I'm not touching a thing until my 5/60 is up!
jhinderliter
Nov 15, 2019 9:23 PM
DVS95Lumina
Dec 24, 2015 3:57 AM
DeHartShadow
Mar 28, 2010 10:10 PM
digdug
Feb 4, 2007 3:08 PM
Black 5.3
Oct 29, 2006 2:45 PM
