08 Tahoe Starting Issue
Old May 18, 2022 | 2:01 AM
Breezy13x's Avatar
Default 08 Tahoe Starting Issue
Hey, I’m new here and normally just try to research my info but I can’t find any ideas and I’m stumped. Anyways, I just recently purchase and 08 Tahoe z71 a few months back. I just recently noticed an issue when starting. Whenever I turn the key over to start, it will randomly “cut out” mid crank for a moment like it isn’t going to start then proceeds to crank and fire right up. The best way I can describe it is like when you go to start your vehicle and your hand slips off to early before it actually fires, if that makes sense. The Tahoe has 95k miles and I’m stumped. The battery is fairly new and the terminals look good and it doesn’t act as if the starter is bad from my experience in the past. Any help would be much appreciated, thanks.
Old May 18, 2022 | 8:37 AM
repairman54's Avatar
Change the crank relay as a first step. They are a cheap part.
Old May 18, 2022 | 9:22 PM
Breezy13x's Avatar
Alright I’ll scoop one up in the morning and try that. Thank you, any other ideas?
Old May 29, 2022 | 6:32 AM
Breezy13x's Avatar
So I changed out the crank relay and still the same issue. Seems to get worse once it’s been drove around for awhile but still doesn’t do the everytime.
Old May 29, 2022 | 6:57 AM
Load test the battery. They can be erratic and any battery over 3 yrs old is suspect.
Clean and tighten battery terminals, looks good may not be enough.
Typerod
Jan 7, 2022 3:39 PM
Rune Larsen
Jan 29, 2017 11:55 AM
Bpurg
Jul 19, 2011 5:57 PM
bob450
Nov 20, 2010 5:13 PM
c62nt62
Sep 25, 2007 7:05 PM
