'09 Tahoe Help how to remove passenger side mirror?
Old Oct 14, 2013 | 4:51 PM
geodavky's Avatar
Default '09 Tahoe Help how to remove passenger side mirror?
The actuator (mirror won't go up and down) on the passenger side mirror is bad and I need to get the mirror apart to replace it. How is this done? The mirror has built in turn signals of that makes a difference.
Old Oct 14, 2013 | 9:28 PM
intheburbs's Avatar
Gently pry off the triangular plastic trim piece on the inside of the door (prying at the top of the piece). This will expose the three nuts and the wiring harness. Unplug the harness, remove the three bolts, and you're done. Use a magnetic socket, if you have one, to make sure you don't drop any of the nuts inside the door.
Old Oct 14, 2013 | 9:39 PM
Here is link to some information I posted a while back about removing and installing the mirror...
https://chevroletforum.com/forum/tah...r-issue-55887/
EDIT: this if for the removal of the glass itself... as stated above the mirror assembly is done from the inside of the door....
Old Oct 15, 2013 | 6:53 AM
geodavky's Avatar
Thank you I was looking for the removal of the glass itself. When the mirror is pushed in at the top there does not seem to be enough room for the glass to be lifted up as it is almost touching the housing. I don't know if these directions are applicable to a 2009? Lifting up under the mirror with a 2" wide flat plastic tool I cannot get the glass to budge and I am affraid I will break either the bottom housing or the glass itself. Any ideas?
Old Oct 15, 2013 | 7:43 AM
This should be applicable to the 2009, as the 2007 to 2014 are all GMT900 models...
Old Oct 15, 2013 | 10:30 AM
geodavky's Avatar
I got the mirror off and now I need to remove the actuator as that is what is bad. How do I get the actuator loose from the housing?
Old Oct 15, 2013 | 10:55 AM
I don't have access to my manuals at the moment, but you might see if you can pop off the back of the mirror cover and access the motor assembly from that point...
Old Oct 15, 2013 | 12:06 PM
geodavky's Avatar
Just took another look and see 4 screws that must be holding it on. I'll try that.
Thanks for all of your help!
Old Oct 15, 2013 | 4:28 PM
Were you able to get it apart and the motor out? take a few pictures and post if you can
Old Oct 16, 2013 | 8:10 AM
geodavky's Avatar
Sorry, but I had it back together before I saw your post asking for pictures. It only took 5 minutes.
It was very straightforward once the mirror was off. Just removed the 4 allen head screws in the actuator, unplugged it, plugged in the new actuator, put the 4 screws back in then the mirror back on.
Thanks for your help
