09 tahoe trying to get my heated seat to come on with remote start
trying to get my heated seats to come on with remote start are their any way to do that also the front seats are cooled as well.
i was under the impression they should as well, let me find the manual pdf:
P2-8
says if you remote start they will turn on during 'colder temperatues' and will shut off when you turn the key to on.
what the hell are 'colder temps'?!
P2-8
It happens automatically in my '07, so it should work in the '09 when it gets cold enough. I haven't been able to get anyone to tell me how cold it must be though, and yes, 2-8 only says "colder temperatures". It says nothing about the the seat cooling feature, so I'm guessing the '09 will not turn on the seat cooling when it's hot.
I tested this when I went to lunch, my driver seat heater was on, i didn't look at passenger.
I remote started, the dash says it is 39 degrees F. '09 LTZ.
I did look in the rear, it looks like the 2nd row does not auto turn on w/remote start... seems like it could!
When AUTO is selected, the air conditioning
operation and air inlet will be automatically
controlled. The air conditioning compressor will run
when the outside temperature is over about
40°F (4°C).operation and air inlet will be automatically
Ride of the Month
May 2009
Ride of the Month
May 2009
I always leave my dual climate thermostat set at 75 degrees and in the Auto mode, in moderate temperatures I will turn off the AC compressor and cool with the fan only if needed. I wonder if the seat heater will only come on if you last had the AC off?
I have had mine come on with temps in the mid 40's lately.
Maybe it'll only come on w/ remote start if it was on when you last shut 'er down. I think that's the way the climate control works. That is if the A/C is off when shut down, it will not come on when remote started even if it's 90* out. At least that's the way mine works. Never checked out the seats.
BigBlackTruck2014
December 9th, 2013 9:55 PM
andyneal
April 1st, 2009 4:49 PM
scott209
December 16th, 2008 4:35 PM
