10W30 Synthetic at 4400 miles?
Old Dec 31, 2007 | 8:34 AM
MCF34's Avatar
Default 10W30 Synthetic at 4400 miles?
I changed my oil at 1500 miles with regular 5W30. Inow have 4400 miles and was going to go 5W30 synthetic blend but my dealer only has 10W30 Mobil 1 Synthetic. Is it ok to put that in at 4400miles or should I stick with 5W30? I live in Houston, Texas where it may freeze once or twice a year. Thanks!
Old Dec 31, 2007 | 8:53 AM
ZX1100F1's Avatar
Default RE: 10W30 Synthetic at 4400 miles?
Your are OK using 10W30 in Houston but try to use 5W30 whenever possible.
Old Dec 31, 2007 | 9:14 AM
MCF34's Avatar
Thanks...is it to early to go with full synthetic?
Old Dec 31, 2007 | 11:38 AM
AZSCTACO's Avatar
ORIGINAL: MCF34
Its never to early
Old Jan 3, 2008 | 1:35 AM
bimmerborn's Avatar
ORIGINAL: MCF34
I wait until 10K miles before going synthetic.
Old Jan 3, 2008 | 8:42 AM
ZX1100F1's Avatar
There is no reason to wait to switch to synthetic, most performance vehicles come factory filled with synthetic oil.
It is an urban legend that synthetic oil is so slippery that it does not allow a motor to break-in properly.
Old Jan 3, 2008 | 10:31 AM
guvner's Avatar
So what part of the truth is it that you never put synthetic in an older engine that doesn't have a leak at this point? I have a 2000 Tahoe with 140,000 miles on it with no leaks. Is it a bad idea to switch at this point?
Thanks... G..
Old Jan 3, 2008 | 10:49 AM
ZX1100F1's Avatar
On an engine with that many miles it would probably be of little benefit to switch to synthetic at this point but it certainly wouldn't hurt anything and if you don't have any oil leaks now you won't if you switch to synthetic oil either. Over the years there has been a lot in the way of folklore conjured up against synthetic oils probably most of it in an attempt to discredit any advertised benefits to rationalize and ease the minds of people who either choose not to use it or can’t afford it however synthetics are superior to conventional oils in virtually every conceivable way.
Old Jan 3, 2008 | 2:58 PM
MCF34's Avatar
OK..I changed my regular oil at 1500miles. Now I have 4500 miles and normally, I change the oil in cars every 3000-3500 miles. Well, I am there but the oil indicator says I still have 50% of oil life left. I only drive 5-6 miles total a day to and from work and to and from the gym during the week and just around town on the weekends. Should I stick with changing oil at 3500 miles or follow the meter. I am sticking with regular 5W30 for at least one more change before going synthetic.
Old Jan 3, 2008 | 10:14 PM
I believe ZX has previously indicated that change at 50% w/ mineral and at 100% w/ synthetic.
Danistheman1234
25
Aug 9, 2011 5:16 PM
Danistheman1234
May 26, 2011 6:59 PM
sclserviceCHAMBERS
May 16, 2011 10:32 AM
blacknblu
Nov 16, 2009 5:16 PM
mike3401
Camaro
14
Sep 22, 2009 11:47 AM
