1988 Sub Trans no forward or reverse gears
Old Dec 23, 2007 | 2:37 PM
wep54's Avatar
Default 1988 Sub Trans no forward or reverse gears
1988 Suburban 350 4x4. Trans has no forward or reverse gears. Nominal amount of copper/brass shavings in pan. Grinds when put into park. Is there a possible fix without pulling the trans or do these symptoms indicate a rebuild? I assume this has a 700 R4. Thanks in advance.
Old Dec 23, 2007 | 9:44 PM
Gryphon's Avatar
Default RE: 1988 Sub Trans no forward or reverse gears
Sounds like rebuild time to me. Be a good time to upgrade your 700R4 (or it may be a TH400?) to the newer sprage assemblies for greater strength...but it has lasted this long, I think it did good! How many miles on it?
Several things it could be. Best to just open it up; my guess is bands or seals, or both. How did it die? Did it go slow, or sudden?
Been a long time since I worked on an auto.
Thundernuts
23
Apr 24, 2022 3:40 AM
livinginsuburbania
Mar 21, 2020 1:55 AM
georgiavol
Jul 17, 2014 8:19 PM
65pony
Sep 9, 2011 10:40 PM
99blue
Feb 18, 2009 5:31 AM
