1989 Suburban 2500 Engine quits after bump
Old Feb 15, 2021 | 7:53 PM
airbusflyboy's Avatar
Default 1989 Suburban 2500 Engine quits after bump
1989 Suburban 2500 4 WD, after hitting ruts or bumps in the road, there is a 20 amp fuse that breaks each time, upon replacing this fuse the engine will start and run again !!! Any ideas, suggestions or ???
Old Feb 15, 2021 | 8:35 PM
Welcome to the forum. When you say the fuse breaks, do you mean blows or actually physically breaks? If it is blowing and it happens when the truck is physically shocked, then there's a circuit that is shorting out. Could be a pinched wire or a wire that's next to hi temp like exhaust manifold that has melted insulation and is shorting out.
Old Feb 23, 2021 | 6:20 PM
As best as I can tell from talking to the owner, this looks like a 20 amp ECM blade fuse, that will burn/break when he hits bumps in the road (?) but I am not sure this is happening at every bump.
The fuse block is located inside the cab of the truck up under the dash panel , sort of difficult to access but it is doable.
I am the new owner of the 1989 Suburban at this time, we have a TH400 hydro tranny in it that is giving us some shifting issues, at times will not get into the 3rd gear and sometimes feels like it is slipping in Drive. Thank you for your inquiry ............... Mark
Apollonick
Nov 20, 2019 10:57 AM
Lipripper15
Jun 15, 2018 12:05 PM
Ashep
Aug 20, 2014 6:45 PM
sub2002
Apr 21, 2011 12:01 PM
07LT3BEE
May 21, 2007 2:46 PM
