1990 GMC Suburban Normal Temp Range
Old Jan 28, 2007 | 12:52 AM
rarchar's Avatar
Default 1990 GMC Suburban Normal Temp Range
Who knows the normal temp range for a GMC 90 Suburban? Mine is running at 210-215. Already changed fan clutch, thermostat, and sensor. Water pump is working and belt is good. Any ideas? Thanks!
Old Jan 30, 2007 | 1:39 PM
Dondobe's Avatar
Default RE: 1990 GMC Suburban Normal Temp Range
Rarchar, You're radiator may need to be baked and rodded. You can take it out your self and have a radiator shop B&R it. This will save you a lot of labor. Radiators over time start have a build up inside them and it restricts the water flow not letting the water coolenough.
Good Luck, Dondobe
Old May 14, 2008 | 11:58 AM
kool radiators's Avatar
You can buy a new all aluminum radiator for your car. Very inexpensive. These radiators are for big blocks and can cool up to 750 hp. I can advise you. Let me know if I can help...
Old May 14, 2008 | 1:05 PM
RonH's Avatar
If your radiatorchecks outOK, check your water pump. Even though the pump is turning, the impeller vanes may be partially worn or disolved away after nearly 20 years in liquid, and the pump may not be moving enough volume to cool the engine.
Old Aug 23, 2008 | 7:31 PM
byronrk's Avatar
Mine was doing the same thing. I changed the thermostat only to have no difference. Tried yet another thermostat and bingo - it worked. My brand new thermostat had been faulty.
ss2202
Aug 20, 2024 12:52 PM
RazzMaTazz
Mar 18, 2015 7:09 PM
tman94
Apr 15, 2014 7:58 PM
espy59lc
Jan 1, 2009 1:16 AM
pstokes
Cobalt
Jul 7, 2008 12:28 PM
