1990 Suburban axel removal
Old Apr 6, 2008 | 4:25 PM
mtomanek's Avatar
Default 1990 Suburban axel removal
I have a 1990 sub with the limited slip rear end. It developed a leak ina rearwheel seal. I have pulled the diff cover off and can see 2 C clips holdin the split axels in place. How the hell do you get those clips off so I can remove the axels?
Thanks,
Matt
Old Apr 7, 2008 | 8:22 AM
jljbtm's Avatar
Default RE: 1990 Suburban axel removal
There is a small bolt holding the center pin in place, rotate the carrier until u see that bolt, remove it and the large center pin should slide out alowing u to push the axels in one at a time. When u push the axel in the c-clip almost always just falls out.
Reverse to install.
sonikamd
Jul 7, 2009 7:59 PM
MMann
Apr 9, 2009 10:07 PM
hfb1957
Aug 1, 2008 6:14 PM
mudderfan
Nov 10, 2007 12:12 PM
