1993 Suburban Transmission Help!
Old Aug 18, 2010 | 7:08 PM
tscheutzow's Avatar
Question 1993 Suburban Transmission Help!
Hello everyone. I decided to buy a new transmission as this is a traveling vehical. I installed the transmission just as I have others and when starting the vehical it made a loud scraping sound as if something was rubbing against the flywheel or torque convertor. After inspecting both components neither had anything rubbing on them.
I'm at a loss. The ECM isn't throwing any tranny codes so I really can't figure out where the noise is coming from. Any ideas?
Thanks,
Tim
Old Aug 19, 2010 | 12:17 AM
2wd-K5's Avatar
did you set the torque converter properly?
Old Aug 19, 2010 | 2:36 AM
tscheutzow's Avatar
I'm not exactly sure what you mean. The convertor was bolted with a bracket to the new tranny. I removed the bracket just before sliding the transmission into position.
Can you elaborate on your question? That must be the issue.
Old Aug 19, 2010 | 2:54 AM
2wd-K5's Avatar
when installing a trans always spin the torque converter and push it into the trans, it seats the torque properly, if you install the converter on the trans or if in your case it was transported then always check if it is seated, also another thing i have seen is somebody installing the flexplate backwards made a wicked chattering sound
93K1500
Nov 18, 2020 12:47 PM
InsanePyro
Mar 4, 2012 4:30 PM
SolomonMan
Jul 25, 2011 8:27 PM
Broshears
Mar 9, 2011 4:30 PM
SolomonMan
Dec 29, 2010 1:54 PM
