1994 suburban starts then stalls out
Old Feb 23, 2007 | 9:21 PM
  #11
dalkins1's Avatar
Default RE: 1994 suburban starts then stalls out
Still fighting with this issue,,,,,,have now changed the ignition lock cylinder to go along with all the other parts. Suburban runs fine,,,but about every other day it will start then quickly stall,,,it will start and stall about 2-4 times before it will stay running fine. I have gotten another code (number 35) IAC valve again,,,,,I have put a new one it so not sure what is going on. I also wiggled numerous wires while it is running to see if I can locate a loose connection. I am stumped at this time,,,,parts I have changed are: dist cap, rotor, ignition module, fuel filter, fuel pump relay, oil pressure switch, plugs, ignition switch and lock cylinder.
Golfer I finally have an answer to your question of the dash lights being on when it stalls,,,,they are not on when it stalls??? not sure what this means? Does anybody think it could be something in the run circuit that loses power when key is realeased just after it starts?
Pleas offer any suggestions I am at a loss at this point, Thanks Dave
Old Feb 23, 2007 | 11:19 PM
  #12
golfer's Avatar
Ok lets review...
- when the vehicle first starts ( cold ) it runs fine and doesn't stall.
- After it's been running a while ( hot ) it stalls and hard to start.
- when it does stall there are no lights lit on the dash
.... is this correct so far?
When it does stall and the radio isplaying will it go off ?
Old Feb 24, 2007 | 3:29 AM
  #13
RonH's Avatar
It really could be a fuel pump. Sometimes they will run fine for a long or short time and then just quit pumping. Turning the key off and on a couple of times until you hear it running again will get it started again, and then it will run for a while just fine before it quits again. Seems like after sitting overnight or for several hours,it runs good for a while before it starts acting up.
Old Feb 24, 2007 | 11:54 AM
  #14
dalkins1's Avatar
Golfer,,,it has since stall out twice when it is first started in the morning????? It stalls out so fast after it starts that I am not sure about the radio.
A funny thing about this suburban, I have never been able to hear the fuel pump running, I have owned it for about 6 weeks now, I think I bought somebodys headache. With my limited knowledge I am thinking its maybe fuel pump or something in the ecm not giving a signal sometimes after it starts? Do you think I am heading in the right direction?
Thanks Dave
Old Feb 24, 2007 | 9:40 PM
  #15
golfer's Avatar
Let's never mind about an electrical problem and I doubt it's the ECM.
The engine needs three things for it to start and run...
1 - air
2 - fuel
3 - spark
You can try having someone turn the key to "on" for the count of 5. During this time you're outside the vehicle listening for the hum from the fuel pump.
There is a magnetic pickup and an ignition module inside the distributor that the ECM reads to control the timing of the spark and the injectors.
You could also have a problem with the fuel pressure regulator.
Old Feb 27, 2012 | 7:20 PM
  #16
CJ Morris's Avatar
Default 1994 suburban has issues when you dont let it warm it up?
This morning I started it fine and ran for about 10 minutes, then took the kids to school. This was about 7 am, at around 10:50 I went out and started it, but only let run for a minute or two then left. The truck sputters and dies repeatedly. The only way to keep it going is continually tapping the gas pedal. Any ideas on what might be going on?
Old Mar 14, 2012 | 3:30 AM
  #17
wishiknew's Avatar
Sounds like you have the same thing I do. I'll let you know when the dudes reply to my thread, haha.
Old Nov 13, 2012 | 2:56 PM
  #18
illinoise's Avatar
I have this exact same issue, except I have a 95.
Has anyone solved this issue?
Dfmatt
1988 - 1998 (GMT400)
19
Aug 29, 2024 1:02 AM
barnmech
Apr 21, 2022 7:38 PM
mark 66
Uplander
Apr 22, 2010 10:09 PM
snowonweb
Oct 25, 2008 3:42 PM
dalkins1
Jan 27, 2007 11:18 AM
