1995 Suburban Cuts out except when its below 20 degrees outside
Old Dec 12, 2007 | 2:33 PM
pookster71's Avatar
Default 1995 Suburban Cuts out except when its below 20 degrees outside
This baby runs great, except occasionally when i take off on a hill from a complete stop, or when it seems the transmission is shifting down and the engine is starting to work a little harder, then it tends to cut out. I have replaced the fuel filter, the injectors, and the fuel pressure regulator on top of the throttle body, but this hasnt fixed the problem. I have not checked the fuel pump yet, but my experience is that it works or doesnt, but that was in older vehicles. PLEASE HELP.
Thank You,
Andrew
Old Dec 27, 2007 | 11:36 AM
1995 SUBURBAN's Avatar
Default RE: 1995 Suburban Cuts out
Hey Andrew, I have a 95 SUBURBAN as well, and I had a similar problem, which masked itself as a FUEL PUMP on the outs. It ended up being my FUEL PUMP RELAY. It actually degraded over a period of a couple months. My wife would be driving it, and all of a sudden, it would shutdown on her. The problem also mimicked an Ignition Control Moduleon the verge of full failure as well. I changed the fuel pump and it worked for a few days, and shutdown again on her, and that is how I finally realized the true problem. HTH's and good luck
Ashley
cave76
Dec 13, 2011 9:07 AM
z06fiend
Dec 8, 2010 7:05 PM
jmadson
Mar 18, 2008 7:49 AM
mmudd
Dec 29, 2007 8:54 AM
carlsndfw
Jan 29, 2007 10:57 AM
