1995 Suburban warm up?
Old Dec 10, 2009 | 11:13 PM
NUTZ's Avatar
Default 1995 Suburban warm up?
Hey Everybody, I've got a problem with my 95' suburban warming up in the Minnesota cold weather. The burb. will not warm up completely idling. While driving it will warm up, but if I turn the heat on it cools down to about 140 degrees. I replaced the T-stat with no luck. The burb has a rear heater so maybe the extra hose length is cooling the system down? just a thought. The catalytic converter was removed by a PO - otherwise the exhaust is stock.
Any ideas on where I should start looking?
Old Dec 11, 2009 | 9:51 AM
T5258's Avatar
What temp t-stat did you install????
Old Dec 11, 2009 | 12:16 PM
SabrToothSqrl's Avatar
Default heat!
my 1995 Tahoe 5.7L would, seriously, take 8 MILES before it would hit 100 degrees and blow heat out... my 09... is warm after 2 miles.
Old Dec 11, 2009 | 1:57 PM
T5258's Avatar
My 95 Suburban needs about 5-7 min of running before the temp gauge even moves....runs @ about 190ish tempwise once the t-stat opens. I have rear heat as well, it doesn't seem to affect engine temp whether on or off....is your fan clutch stuck I wonder.....????
Old Dec 11, 2009 | 1:58 PM
NUTZ's Avatar
I installed a 195 deg thermostat - I let it warm up this morning for 10 min with the heater fan on low and it barely warmed up to 100 deg. Perhaps these 95's take longer to warm up.
Old Dec 11, 2009 | 5:16 PM
mudmaniac's Avatar
Ride of the Month
May 2009
The cast iron blocks take much longer to heat up than the new aluminum blocks do, in your area you may want to partially block the radiator.
Old Dec 14, 2009 | 8:04 AM
T5258's Avatar
I'd also check to make sure the t-stat isn't sticking...new or not, I've seen it happen. Did you have the Burb last winter, & if so, how was the temp running then??
Old Dec 15, 2009 | 8:02 AM
NUTZ's Avatar
This is the first winter for the burb and I will give the t-stat a check. I've run into problems with new ones sticking open as well. I will go to the dealership and get an OEM stat and see if that helps. I let ya know what happens.
Old Dec 22, 2009 | 11:05 PM
NUTZ's Avatar
Today I finally got around to switching out the t-stat and I am happy with the results. The burb warms up faster and stays warm - unlike before.
Mission complete - now on to the next project with the burb.
Old Nov 11, 2012 | 4:32 PM
thor5512's Avatar
I had the same problem. Check the compression on each piston. If you are too low it will send a code to the computer and you will not heat correctly. As well as a few other issues, that was the major one I had.
Mirza Baig
Jul 10, 2014 10:25 AM
doctorsevarg
May 31, 2014 10:23 PM
aubiexx
May 3, 2011 8:57 PM
ajrkar
Jul 21, 2010 11:26 AM
kane marsee
Aug 20, 2009 7:51 PM
