1996 Suburban AC problem
Old May 7, 2008 | 8:55 PM
bigbob's Avatar
Default 1996 Suburban AC problem
Before I tell you my problem let me first say thanks to all you folks for monitoriing this forum and offering for free your expert advice. I'm a pastor and can't afford new cars so I've go to be able to repair and keep my machines running. Thanks!
I have a 1996 Chev Suburban 4x4 350. Last summer the AC stopped blowing cold air. Everything works fine just warm air instead of cold air.
So this week I went and got a recharge kit. I turned on the burb, turned on the AC connected the refrigerant (following the directions) can with pressure guage. The pressure was low--less than 10 psi. So I shot some into the system until it reach about 35psi. Then the compressor turned on (or engaged). Yikes, the pressure dropped back to 10. The compressor disengaged. The pressure went back up to 35psi. Back and forth every 5 seconds. (I think they call this short cycling). So, I thought the system needed more R-134A so I took the pressure up the 45psi. Then the compressor would engaged and drop down to about 20ps. I drove it around no cold air. The compressor would just go on and off.
The problem is that I cannot add more A-134A because I'm at 45psi and that is in the Yellow on the gauge that says "Alert" don't add more refrigerant.
So now what? do I have a bad compressor? How to I get the compressor to stay engaged so the refrigerant will cycle through and equalize the pressure.
Any help or thoughts would be appreciated.
Robert (bigbob)
grg3024
Dec 18, 2013 11:09 PM
peerware
Jul 9, 2013 9:48 AM
Mr.mallard
Sep 8, 2011 10:04 PM
Rivernut
Nov 13, 2007 12:24 PM
jheddlesten
Sep 17, 2007 5:51 PM
