1997 Chevy Tahoe-Check Engine Light
Old Jul 21, 2013 | 1:47 PM
warf1955's Avatar
Question 1997 Chevy Tahoe-Check Engine Light
Check engine light on. Had my check engine light checked adn got a code P0719 with a definition of brake switch circuit low input. The explanation is vechicle speed over 35 mph and down to 0 mph 5 times- No change in brake switch input detected. could this be a bad brake switch orsomething else. Also the brakes feel ok when stopping, but when you are at a dead stop the breaks feel spungy . You can push the brake pedal almost all the way to the floor board. Thanks in advance.
Old Jul 21, 2013 | 4:19 PM
Have you checked the brake switch? make sure all the wires are firmly connected and the switch actuates...
Might also want to check all fuses to make sure its not a blown fuse....
As for the spongy... when was the last time the brake system was bled?
Could also be a bad brake booster...
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
sse123321
Nov 7, 2010 5:28 PM
