1997 dist cap and rotor
Old Mar 26, 2011 | 7:30 AM
shamrock246's Avatar
Default 1997 dist cap and rotor
Anybody now if the DELFI cap and rotor they sell at Napa is really OEM like they say?same as AC/delco?,is MSD or ACCEL better?
thanks
Sean
1997 1500 burb
Old Mar 26, 2011 | 7:45 AM
You can't go wrong with the AC/Delco brand, unless you have done heavy mods to the engine and have a non standard ignition system OEM is the way to go. Its possible the Delphi brand is a repackaged version of the AC.
note: all manufactures of the parts can clam they are of OEM spec (which can be true however, that can be minimum spec it doesn't mean they have to meet all)
Old Mar 27, 2011 | 3:10 PM
Thanks in2pro,i found AC/DELCO on Summit racing and the prices were real good the problem i'm having is hard starting and running rough if it rains out the night before if it didn't it starts right up and runs great i have a new set of 8.5mm wires and new plugs witch did solve this problem,i sprayed water on the coil while the engine was running and it still ran good the wires did smooth it out somewhat,the upgraded spider made a difference also
Sean
1997 burb 1500
Old Mar 27, 2011 | 4:01 PM
Have you checked fuel pressure, I know it doesn't seem related but it could be...
Old Mar 27, 2011 | 5:07 PM
not yet i need to get a tester good investment since my boat has the same motor except with the marine manifold and no EGR and MAF,when i bought the boat they where picky about making sure the fuel pressure was right it had to be writen on the warrenty paperwork
Sean
1997 burb 1500
Old Apr 10, 2011 | 7:51 AM
update: i got a AC/DELCO cap and rotor from Summit the rotor had a blue plastic shield installed between the center and tip, my old rotor didn't have this and i found some small black cracking in the old cap right above this area i'm thinking when it was wet out side it would arc up to another cylinder in the firing order because after three different rainy nights it fired right up without a problem
now to work 02 code PO141
thanks
Sean
97 4x4 burb
rowekmr
Jan 7, 2020 6:14 PM
93ChevyVan
Dec 20, 2013 8:58 AM
Mauber90
Feb 2, 2013 11:19 AM
DennisT
Jan 22, 2010 3:08 AM
gearhead_12
Sep 22, 2007 11:10 AM
