1997 K1500 DIY Catalytic Converter
how many miles / how old? my head hurts, but here's the link...
http://www.epa.gov/oms/consumer/warr95fs.txt
8/80,000 is the federal coverage on stuff... I used this on my 1998 wrangler when the cat blew out...
lol 1997 --> 2010 = 13 years... I guess your a little over...
Hey guys,
Thanks for the reply, I have more info directly from the dealer. I was quoted $1800 to replace CAT Converter, a seal (I assume to the converter) X2, a gasket and three sensors. Part numbers are as follows:
15093974 SEAL Where does this get installed?
15746547 CAT CONVERTER " "
15051878 GASKET " "
19178116 OXYGEN SENSOR " "
19178934 SENSOR " "
25312191 SENSOR " "
This job does not seem very labor intensive due to the dealer part pricing is $1510.39. If I can find the parts online cheaper(I am sure I can) and you guys could help me with the DIY labor, I am on my way to saving big bucks!!!
Please help
15051878 GASKET " "
19178934 SENSOR " "
25312191 SENSOR " "
Please help
There is really no special knowledge needed to replace parts in an exhaust system other than skill in removing rusted bolts. An independent exhaust shop may be able to give you a lot better price than the dealer. If you do it yourself, all you will really need is hand tools and a torch to heat up stuck bolts. However, an impact wrench would be handy.
Check gmpartsdirect.com with the part numbers you have and compare to the dealer part price.
Oxygen sensors generally go into the exhaust pipe similar to a spark plug. Screw it in and plug it into the harness. The other sensors are only listed as "Computer Sensors" in GMPartsDirect. I don't know where they go or how they are installed.
Ride of the Month
May 2009
Ride of the Month
May 2009
Vester is right, the last 2 sensors are listed as computer sensors. They may also mount in the cat, it list having 3 sensor locations. If you but the parts direct and take a look at them you should be able to match them up. If not then post some pics of them and we can help you with it.
jpak3030
Mar 25, 2010 10:37 PM
hines182
Jul 28, 2007 6:47 PM
