1998 Suburban starting issues
Old Nov 26, 2025 | 2:32 PM
JJL's Avatar
JJL
Default 1998 Suburban starting issues
Went to start my Suburban after replacing my window switch. Engine starts then dies. Did this several times. Put a fuel press gauge on and have around 54 psi. Holds steady with key on and off. What is the fuel press minimum for this truck ? It's a 5.7 engine. Thanks!
Old Dec 1, 2025 | 6:32 AM
Davo's Avatar
Good morning. I would look at the in tank pump. here's why: for your 1998 Suburban with the 5.7L Vortec engine (L31), the required fuel pressure is 60-66 PSI. Your reading of 54 PSI is too low and is almost certainly the cause of your problem.
I was having the same problem and realized that my 27 year old in-tank fuel pump was not quite up to par. Obtained a new one (1A Auto is my dealer of choice for most of my parts). Pump was under $60 and the labor was the killer. I'm a disabled Vet so I don't turn too many wrenches anymore so DIY was out of the question.
Good luck, hope this helps and happy trails!
Tom ward
Aug 22, 2022 8:49 PM
Benrock05201
Jul 2, 2014 10:54 PM
digordo1
Jul 27, 2011 9:26 PM
sirhcsti
Jan 12, 2010 6:25 PM
DDOORS
Oct 15, 2006 8:34 PM
