Stalling issues
Old Aug 21, 2022 | 4:35 PM
Tom ward's Avatar
Default Stalling issues
I have a 96 suburban with the 5.7 that I use to haul my 7x16 enclosed to dirtbike races. Last few races it has died 15 to 20 miles from the house. Starts up within a minute. Then it's good the rest of the weekend. Last 3 races it's done it and they've been 3+ hours from the house. The suburban sits a couple weeks between raves sometimes. Thanks.
Old Aug 22, 2022 | 11:04 AM
repairman54's Avatar
When was the last time you changed the fuel filter ? They are a 30k mile service item and that is a symptom.
Old Aug 22, 2022 | 12:34 PM
Tom ward's Avatar
Around 7500 miles replaced the fuel pump at same time. Used a Delphi pump
Old Aug 22, 2022 | 2:28 PM
Kenrbass's Avatar
Ignition module, then ign sw, is where I would start as a retired mechanic. That is if it cuts off like a light switch. If it stumbles and dies slowly, I would be looking at fuel issues.
Old Aug 22, 2022 | 3:23 PM
Tom ward's Avatar
I'll try ignition module. it just shuts off like a switch. No stumbling. Thanks!
Old Aug 22, 2022 | 8:49 PM
Kenrbass's Avatar
There is a pickup coil in the dist also. Often, I would pull the dist and replace both
gibby13
Aug 8, 2018 2:18 PM
bridges0924
Sep 1, 2017 5:47 PM
Codifer86
Dec 26, 2015 10:46 PM
Jeremyaayala
Jul 20, 2013 7:35 AM
novato1
Oct 29, 2007 11:27 PM
