1999 Chevy Suburban Valves Tapping
Changed wires, plugs, dist cap and rotor two weeks ago. Yesterday the engine started making a loud knocking sound. Sounds like the valves are tapping. I checked all fluids and everything is at the proper levels. It doesn't make the noise in park only when you drive it and put a load on it. Was told possibly water pump but checked that and it's not loose.
Only thing i can think of would be a mis aligned plug wire. maybe double check them to make sure they are going to the proper plug. Also i have had a distributer cap come loose and the rotor was tapping the pegs in the cap and sounded alot like what you are talking about. just some things to check
Rescue30
June 29th, 2007 12:59 PM
