1999 Sub. Brake problems
Old May 6, 2011 | 5:45 PM
jmw's Avatar
jmw
Exclamation 1999 Sub. Brake problems
Almost $1800 into my brakes and it still shakes. Can't figure out why, will you give it a try?
Old May 6, 2011 | 6:12 PM
hicksvilleshick's Avatar
I guess before I could venture a guess it would require more of a description of the problem... other than you've paid far too much for any kind of brake shake I can imagine... 1800? thats um, well, you should have a brand new brake system for less than that.
:chug:
Old May 8, 2011 | 9:56 PM
jmw's Avatar
jmw
It is a completely new brake system. New vented and dimpled rotors, ceramic pads, calipers, wheel cylinders, ceramic shoes, drums, spring kits. The GM dealer could not accurately diagnose the problem. Two local brake shops came up with issues that turned out to be wild goose chases that cost me $700. I am at my wits end and just about ready to send it down the road!!
Old May 9, 2011 | 9:24 PM
ok, need more info. the more descriptive the better. when does it shake? only under pedal pressure? foot off the brake?
have you had the steering checked (might be a dumb question, but if you've got a worn out front end.....) by someone trustworthy?
chain of events might be helpful too.
:chug:
danielcwebb
Apr 4, 2014 12:28 PM
99-Sub
Aug 27, 2013 9:43 AM
jmw
May 6, 2011 5:37 PM
mellowme
Jul 20, 2010 12:00 AM
BUB20789
Camaro
Dec 23, 2008 12:00 PM
