1999 Suburban
Old Jul 1, 2013 | 3:37 PM
jacksonhayden53's Avatar
Default 1999 Suburban
I am looking to put straight pipes on my burb and i was trying to figure out what the best size pipe should use.
Old Jul 1, 2013 | 4:16 PM
Joe In NY's Avatar
Are you going to gut the cats? Straight pipes don't sound good with cats...
Old Jul 4, 2013 | 11:40 PM
phinattic's Avatar
I would advise against putting straight pipes on your suburban, you are asking for trouble if you cut out the cats. You have 4 O2 sensors two before and two after your cats if you take them out your SEL will stay on and the motor will not run right. Do a cat back dual exhaust put some Flowmasters on it or Magnaflo mufflers and you will be much happier with it.
Old Jul 5, 2013 | 12:22 AM
Alright thanks for the help.
Old Jul 5, 2013 | 11:47 PM
Sledgehammer's Avatar
and remember that the burb amplifies the sound inside not like a pickup where it is outside.
Old Jul 6, 2013 | 6:23 AM
alright i am not really sure what that means?
Old Jul 7, 2013 | 3:23 AM
it means that all the noise and vibrations will come back inside . kinda like an echo inside the truck. with a pickup the vibrations and noise will be more outside as there is noting above the exhaust (in the back) that is directly linked to the inside
69hdflh
Oct 27, 2006 5:54 PM
Miichael
Oct 25, 2006 2:41 AM
bdog
Oct 3, 2006 8:05 PM
bdog
Aug 7, 2006 6:47 PM
