1999 Suburban brake control
Old Jun 11, 2013 | 8:01 AM
rosslawncare's Avatar
Default 1999 Suburban brake control
I am installing an electric brake control and cannot find the break/stop wire that comes from switch. I have checked all of the wires from it and none are the right one. There are several that are hot but when the break is pressed they are not hot. I thought it was the white wire but it not showing any power at all.
Old Jun 11, 2013 | 9:47 AM
That's because most loads are switched to ground. You need to find a 12V source and use the switch to control it.
Old Jun 11, 2013 | 10:15 AM
Can i go into the fuese box and use one from there.
Old Jun 11, 2013 | 8:09 PM
Connect 12 volts to one side of your load and the other side to the switch that you're going to use such as the brake switch to pull that to ground.
Old Jun 12, 2013 | 3:22 PM
98BlueTahoe's Avatar
I installed a brake controller in my wife's 98 Tahoe, and connected the hot wire to one of the Auxiliary terminals located on the firewall side of the fuse box under the hood. I pulled the 30Amp fuse shielding it, and replaced it with an Auto resetting 30Amp circuit breaker.
tnelliott3
Nov 13, 2024 6:24 PM
Acer12
Mar 11, 2015 12:26 PM
mtp9302
Jun 18, 2013 5:09 PM
rosslawncare
Jun 11, 2013 7:53 AM
B'rt owner
Jan 13, 2011 11:57 PM
