1999 tahoe 5.7 with 0 fuel pressure
Old February 1st, 2020, 9:31 PM
Harlan's Avatar
Default 1999 tahoe 5.7 with 0 fuel pressure
I have a 1999 tahoe 5.7 with 0 fuel pressure. Will turn over, but is misfiring and sounds very odd.
I've replaced the fuel pump relay and put in a new fuel pump...I can hear the pump cutting on when I cycle the key...but I'm still getting 0 psi with my fuel pressure guage.
I'm thinking the computer is bad...or possibly a bad ground somewhere.
Anyone have any ideas?
Thanks!
Old February 2nd, 2020, 4:17 AM
oilcanhenry's Avatar
Thanks!
Perhaps pressure gauge is bad?
Old February 2nd, 2020, 7:18 AM
Did you change the fuel filter or check the fuel pressure regulator?
Old February 2nd, 2020, 7:41 AM
Harlan's Avatar
I checked the gauge with another vehicle and it worked
Old February 2nd, 2020, 1:55 PM
plugged filter
Old February 2nd, 2020, 2:56 PM
Harlan's Avatar
plugged filter
I put in a new fuel filter when I changed the pump
Old February 2nd, 2020, 3:00 PM
Harlan's Avatar
yes...I changed the fuel filter when I changed the pump...ths wire harness to the pump is original...i wish I would have changed it when I had the tank out
maybe it is the harness...when I turn the key on I dont hear the pump....but when I turn the key off..I hear the pump turn on
Rca1965
December 19th, 2020 6:02 PM
Harold Cross
January 4th, 2020 2:57 AM
Nathan Rivers
July 7th, 2019 9:50 PM
servicerepair2013
April 14th, 2017 9:50 AM
mattysgarage
March 23rd, 2012 4:00 PM
Quick Reply: 1999 tahoe 5.7 with 0 fuel pressure
