2000 Sub AutoLeveling not working
Old Jul 9, 2009 | 12:24 PM
kjung's Avatar
Default 2000 Sub AutoLeveling not working
I just noticed recently that the my auto leveling is not working. Upon starting the vehicle the truck usually levels, which you can audibly hear. Are the shocks in the rear air shocks and could they be the problem? Has anyone had the same problem and if so what fixed the issue. Thanks in advance.
Old Jul 22, 2009 | 12:10 PM
tu3712's Avatar
I am having the same problem. Have you figured out what your problem was yet? Mine will also not adjust to a heavier weight in the rear causeing for the back end to ride lower and drag when pulling out of the drive.
TIA
Old Jul 23, 2009 | 8:13 AM
SabrToothSqrl's Avatar
Default disable
is there anyway to disable the auto leveling? when launching my boat on a ramp, it hikes the *** end way up in the air, makeing the boat trailer so steep the boat can't float off right.... i guess I need a drop hitch like 6"... the hitch is already mounted to the truck higher than my 95 and then the leveling thing make it super high when its on a slanted launch with that much weight...
Old Jul 23, 2009 | 2:52 PM
I had to use a hitch w/ a 9" drop to get the proper height for the trailer. Never had any problem when launching/retrieving my jetski. I realize it's not as heavy as a boat but if your system is jacking the rearend up when you're on a steep boat ramp, then I suspect something is wrong. Try measuring the height of hitch on level ground and then when launching the boat. Should be close to the same.
Old Sep 14, 2009 | 6:43 PM
kjung's Avatar
No I have not found the problem. What I also noticed that my tow/haul mode is also not working. Not sure if these two things are interrelated or not. I did check some of the related fuses but they all looked okay.
Old Sep 16, 2009 | 10:32 PM
ff958's Avatar
I just fixed mine on the 02. There is a fuse in the underhood box labled RTD that is for the AutoRide. I had to replace the compressor on mine, it is behind the drivers side rear tire.
Old Oct 29, 2009 | 2:29 PM
deckerchevys's Avatar
Question
Hey all, I posted this on another (older) forum, but have replaced a height sensor and the rear air shocks and now the solenoid on my compressor is not working -- '00 burban. Was looking at buying the compressor from arnotteindustries -- got the shocks from these guys & intalled myself, no problem !! Has anyone got the compressor from them or can just the solenoid be replaced? I've got close to a grand into this system and its still not working so I'd love any advice -- thanks.
RaggedEdge
Jun 8, 2014 9:10 PM
chamadi
Jul 27, 2012 7:59 PM
Twim
May 26, 2011 1:25 AM
owhatathrill
Aug 1, 2009 6:58 AM
cargosub
Jul 12, 2006 3:10 AM
