2000 suburban 5.3 vaccum thru dipstick
Old Aug 3, 2014 | 2:20 PM
2000suburbanjeff's Avatar
Default 2000 suburban 5.3 vaccum thru dipstick
Ok i have 2000 suburban 5.3 vortec first year for this engine.i notice when pulling the dipstick out.i have a small amount of vaccum is it spouse to do that?
Old Aug 3, 2014 | 5:08 PM
I have never bothered to see if you get a vacuum draw through the dip stick hole but I suppose you would, after all that is what the PCV is doing, ventilating the crank case...
Old Aug 3, 2014 | 5:24 PM
Alright thank's that take care 1 problem.reason i ask is because i have little blue smoke.after long idle like 5 min's when i revv it.but after the smoke goes away.have did compression test there all good 165 psi all 8.
Old Aug 3, 2014 | 7:10 PM
Probably valve seals.
Old Aug 3, 2014 | 8:05 PM
Thank you people glad to find out it nothing to bad.because tbh with yall i got 13000 into when i'm done with the brake line fuel line
Z71Grl08
Aug 2, 2011 8:12 PM
julosibia
Apr 8, 2010 10:06 AM
frickenbored
K5 Blazer
Oct 6, 2009 11:44 AM
davidl
Mar 1, 2009 11:36 AM
