2000 suburban blue smoke problem help.
Old July 19th, 2014, 1:29 PM
  #21
You can either buy an adapter to put in the spark plug hole for the air compressor or make one by knocking the insulator out of a spark plug and brazing an air fitting to it. Get a valve spring compressor. Remove the valve covers and rocker arms. Apply air to the cylinder to keep the valves from dropping down (they're hard to retrieve, DAMHIK), compress the valve spring, remove the keepers and old seal. Install new seal and keepers and release the valve spring. Rinse and repeat seven more times and replace valve covers w/ new gaskets.
Old July 19th, 2014, 11:11 PM
  #22
2000suburbanjeff's Avatar
Right i'm just gonna let someone do it.
mmoore031908
March 14th, 2014 8:39 PM
warrior23
September 1st, 2013 10:35 AM
jdshwk
11
September 7th, 2012 11:40 PM
93HEAVY(BUBBLE)
May 12th, 2011 5:00 AM
Quick Reply: 2000 suburban blue smoke problem help.
